Ana içeriğe geç
Acer Aspire One ZG5 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: adım 2, 1 resimden 1.
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: adım 3, 1 resimden 1.
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: adım 5, 3 resimden 1. Acer Aspire One ZG5 Keyboard Replacement: adım 5, 3 resimden 2. Acer Aspire One ZG5 Keyboard Replacement: adım 5, 3 resimden 3.
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: adım 6, 2 resimden 1. Acer Aspire One ZG5 Keyboard Replacement: adım 6, 2 resimden 2.
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: adım 7, 2 resimden 1. Acer Aspire One ZG5 Keyboard Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Doug Gallatin
6.337 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G49
5 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 24,775
