Ana içeriğe geç
Acer Aspire R R5-471T-51UN Display Assembly Replacement
Neye ihtiyacın var
  1. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 2, 3 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 2, 3 resimden 2. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 2, 3 resimden 3.
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 3, 2 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 3, 2 resimden 2.
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 4, 3 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 4, 3 resimden 2. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 4, 3 resimden 3.
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 5, 2 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 5, 2 resimden 2.
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
  6. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Display Assembly: adım 6, 3 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Display Assembly: adım 6, 3 resimden 2. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Display Assembly: adım 6, 3 resimden 3.
    • Using the Phillips #0 screwdriver, unscrew the eight 5mm screws securing the screen brackets in place.
  7. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 7, 3 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 7, 3 resimden 2. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 7, 3 resimden 3.
    • Using the spudger, push up the locking tab of the ZIF interconnect cable so that the ribbon cable pops out.
  8. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 8, 2 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 8, 2 resimden 2.
    • Disconnect the coaxial cables on the Wi-Fi card by pinching the ends of the cables and slowly pulling them out.
    • Using the Phillips #0 screwdriver, unscrew the 3mm screw holding the Wi-Fi card in place and take out the card.
    • Pry up the display brackets so they are clear of the motherboard and case.
  9. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 9, 3 resimden 1. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 9, 3 resimden 2. Acer Aspire R R5-471T-51UN Display Assembly Replacement: adım 9, 3 resimden 3.
    • Gently pull off the display assembly so that it comes apart from the rest of the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 303
