Giriş
If you ever need to replace the SSD in your Acer Aspire R R5-471T-51UN, then this guide is for you. Here, you will be using tools like the Jimmy and the Phillips #0 screwdriver to disconnect certain components. Step 5 asks you to be cautious when removing the battery. Before you begin, power off the device and disconnect from any external connections.
Neye ihtiyacın var
Flip your laptop over so the bottom is facing you.
Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
Using the Phillips #0 screwdriver, unscrew the single 5mm screw holding the SSD in place.
2 farklı kişi bu kılavuzu tamamladı.
