Giriş
Here is a guide to help you remove sticky hinges.
Neye ihtiyacın var
Flip the laptop on to its front, so that the back is facing up
Unscrew the twelve 19.05 mm PH#0 screws.
Bu adımda kullanılan alet:Anti-Static Wrist Strap$7.95
Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
Located at the top are two silver plates that connect to the laptop screen. These are your hinges.
Remove the two 12.7 mm PH#0 screws on each hinge.
After the front and back of the screen are separated, look for any wires the may prevent complete separation. There are 2 wires located by the hinges.
Disconnect each wire and remove the tape if necessary. All screen wires tucked into the plastic part of the hinges can be exposed by pulling on them.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
where would i get the new hindge?
can’t do it i don’t what to brake the screen and buy a new one
