Ana içeriğe geç
Acer Aspire R5-471T-52EE Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: adım 1, 2 resimden 1. Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: adım 1, 2 resimden 2.
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Screen Replacement: adım 2, 1 resimden 1.
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Screen Replacement, Screen: adım 3, 1 resimden 1.
    • Disconnect the three wires from the motherboard that connect to the screen.
    • Be very gentle when removing these wires as the connections with the motherboard are delicate.
  4. Acer Aspire R5-471T-52EE Screen Replacement: adım 4, 1 resimden 1.
    • Remove the eight 3mm screws on the hinges using the Phillips #1 screwdriver.
    • Now that the hinges have been unfastened, carefully separate the screen and screen casing from the other half of the computer.
  5. Acer Aspire R5-471T-52EE Screen Replacement: adım 5, 2 resimden 1. Acer Aspire R5-471T-52EE Screen Replacement: adım 5, 2 resimden 2.
    • Using a spudger or an opening pick, pop open the case holding the screen. Follow the line where the two pieces of the case meet all around the screen.
    • Remove the display assembly from the device.
Sonuç
To install the screen and reassemble your device, follow these instructions in reverse order.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 342
