Ana içeriğe geç
Acer Aspire R5-471T-52EE Speakers Replacement
Neye ihtiyacın var
  1. Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: adım 1, 2 resimden 1. Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: adım 1, 2 resimden 2.
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Speakers Replacement: adım 2, 1 resimden 1.
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Speakers Replacement, Battery: adım 3, 1 resimden 1.
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
  4. Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: adım 4, 2 resimden 1. Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: adım 4, 2 resimden 2.
    • Gently peel off all of the black take that sticks down the speaker cables.
    • Disconnect the two ribbon cables to allow the speaker cable to be removed from underneath.
    • Unplug the speaker cable from the motherboard.
    • Using a spudger, gently remove the speakers from the device.
Sonuç
Bir Yorum
I want to replace my laptop speakers but I am not getting them from anywhere, please send a purchase link also if you have the same speakers. email : prdp9101.com@gmail.com
pradeep singh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 254
