Ana içeriğe geç
Acer Aspire R5-571T-57Z0 Display Assembly Replacement
Neye ihtiyacın var
  1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  2. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: adım 2, 2 resimden 1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: adım 2, 2 resimden 2.
    • Remove the six 4.0 mm screws from the hinges using a Phillips #00 screwdriver.
  3. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 3, 2 resimden 1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 3, 2 resimden 2.
    • Peel back the stickers from the display cable.
  4. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 4, 3 resimden 1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 4, 3 resimden 2. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 4, 3 resimden 3.
    • Hold back the film protecting the Wi-Fi card.
    • Disconnect the touch screen cable.
  5. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 5, 2 resimden 1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 5, 2 resimden 2.
    • Pull back the tape covering the connectors.
    • Detach the two connectors (one black wire, one white wire).
  6. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 6, 2 resimden 1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 6, 2 resimden 2.
    • Disconnect the touch control cable next to the black film.
  7. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 7, 2 resimden 1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: adım 7, 2 resimden 2.
    • Flip over the laptop and pull back to remove the display assembly.
Sonuç
Kevin Chen
133 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Botvin Spring 2022 UMass Dartmouth, Team 1-2, Botvin Spring 2022 üyesi
UMASSD-BOTVIN-S22S1G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 220
