Ana içeriğe geç
Acer Aspire R5-571T-57Z0 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire R5-571T-57Z0 Hard Drive Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove twelve 4.0 mm screws from the back of the laptop using a Phillips #00 screwdriver.
  2. Acer Aspire R5-571T-57Z0 Hard Drive Replacement: adım 2, 2 resimden 1. Acer Aspire R5-571T-57Z0 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use a nylon spudger to pry open the back of the laptop and remove it.
  3. Acer Aspire R5-571T-57Z0 Hard Drive Replacement, Battery: adım 3, 2 resimden 1. Acer Aspire R5-571T-57Z0 Hard Drive Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  4. Acer Aspire R5-571T-57Z0 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Acer Aspire R5-571T-57Z0 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Lift the hard drive either by hand or with a spudger.
    • Unplug the connector cable to remove the hard drive from the laptop.
Sonuç
John Willy
199 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Botvin Spring 2022 UMass Dartmouth, Team 1-2, Botvin Spring 2022 üyesi
UMASSD-BOTVIN-S22S1G2
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 390
