Ana içeriğe geç
Acer Aspire R5-571T-59DC Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire R5-571T-59DC Fan Replacement, Back Cover Panel: adım 1, 2 resimden 1. Acer Aspire R5-571T-59DC Fan Replacement, Back Cover Panel: adım 1, 2 resimden 2.
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Fan Replacement, Battery: adım 2, 3 resimden 1. Acer Aspire R5-571T-59DC Fan Replacement, Battery: adım 2, 3 resimden 2. Acer Aspire R5-571T-59DC Fan Replacement, Battery: adım 2, 3 resimden 3.
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Fan Replacement, Fan: adım 3, 1 resimden 1.
    • Remove the seven 0.7mm Phillips #00 screws securing the fan in place.
  4. Acer Aspire R5-571T-59DC Fan Replacement: adım 4, 1 resimden 1.
    • Unplug fan from motherboard.
    • Lift and remove fan from case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jakobi Peets
335 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,298
