Ana içeriğe geç
Acer Aspire R5-571T-59DC Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: adım 1, 2 resimden 1. Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: adım 1, 2 resimden 2.
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: adım 2, 3 resimden 1. Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: adım 2, 3 resimden 2. Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: adım 2, 3 resimden 3.
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC Hard Drive Replacement: adım 4, 1 resimden 1.
    • Lift the hard drive up and out of the laptop.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kelly Johnston
600 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G2
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
I have bent the pins on my ZIF socket for my Aspire Laptop. Do you have the product name and number or know where I could buy a replacement part?
Samwise - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 4,580
