Ana içeriğe geç
Acer Aspire R5-571T-59DC RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: adım 1, 2 resimden 1. Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: adım 1, 2 resimden 2.
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC RAM Replacement, RAM: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  3. Acer Aspire R5-571T-59DC RAM Replacement: adım 3, 3 resimden 1. Acer Aspire R5-571T-59DC RAM Replacement: adım 3, 3 resimden 2. Acer Aspire R5-571T-59DC RAM Replacement: adım 3, 3 resimden 3.
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelly Johnston
600 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G2
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
How many slots for RAM does this laptop have? Is there a soldered stick in one of the slots? Thanks!
Alberto Einsteino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 990
