Ana içeriğe geç
Acer Aspire R7 AC Socket Replacement
Neye ihtiyacın var
  1. Acer Aspire R7 AC Socket Replacement, Cover: adım 1, 1 resimden 1.
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 AC Socket Replacement: adım 2, 3 resimden 1. Acer Aspire R7 AC Socket Replacement: adım 2, 3 resimden 2. Acer Aspire R7 AC Socket Replacement: adım 2, 3 resimden 3.
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 AC Socket Replacement: adım 3, 1 resimden 1.
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 AC Socket Replacement, AC Socket: adım 4, 3 resimden 1. Acer Aspire R7 AC Socket Replacement, AC Socket: adım 4, 3 resimden 2. Acer Aspire R7 AC Socket Replacement, AC Socket: adım 4, 3 resimden 3.
    • Locate the AC Socket ribbon connector
    • Loosen the ribbon connector using the plastic opening tool
    • Pull the ribbon connector away from the motherboard
  5. Acer Aspire R7 AC Socket Replacement: adım 5, 2 resimden 1. Acer Aspire R7 AC Socket Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
    • There is two sided tape holding this component to the case
    • Once the tape on the Socket is loose, pull up and away from the case to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Rodiek
601 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G4
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,426
