Ana içeriğe geç
Acer Aspire R7 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire R7 RAM Replacement, Cover: adım 1, 1 resimden 1.
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 RAM Replacement: adım 2, 3 resimden 1. Acer Aspire R7 RAM Replacement: adım 2, 3 resimden 2. Acer Aspire R7 RAM Replacement: adım 2, 3 resimden 3.
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 RAM Replacement: adım 3, 1 resimden 1.
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Push the retaining clips away from the RAM module, allowing the spring loaded hinge to pop up.
  5. Acer Aspire R7 RAM Replacement: adım 5, 1 resimden 1.
    • Carefully pull the RAM module away from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Rodiek
601 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G4
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 2,196
