Ana içeriğe geç
Acer Aspire R7 Speakers Replacement
Neye ihtiyacın var
  1. Acer Aspire R7 Speakers Replacement, Cover: adım 1, 1 resimden 1.
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Speakers Replacement: adım 2, 3 resimden 1. Acer Aspire R7 Speakers Replacement: adım 2, 3 resimden 2. Acer Aspire R7 Speakers Replacement: adım 2, 3 resimden 3.
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Speakers Replacement: adım 3, 1 resimden 1.
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Speakers Replacement, Speakers: adım 4, 2 resimden 1. Acer Aspire R7 Speakers Replacement, Speakers: adım 4, 2 resimden 2.
    • Locate the clip attaching the right-side speakers to the motherboard.
    • Carefully pull on the clip until it detaches from the motherboard.
    • Use a plastic opening tool if needed.
  5. Acer Aspire R7 Speakers Replacement: adım 5, 2 resimden 1. Acer Aspire R7 Speakers Replacement: adım 5, 2 resimden 2.
    • Remove the two 3.5mm #00 Phillips screws which hold the speaker in place.
    • Carefully lift the right-side speaker assembly away from the motherboard.
  6. Acer Aspire R7 Speakers Replacement: adım 6, 2 resimden 1. Acer Aspire R7 Speakers Replacement: adım 6, 2 resimden 2.
    • Locate the clip attaching the left-side speakers to the motherboard.
  7. Acer Aspire R7 Speakers Replacement: adım 7, 2 resimden 1. Acer Aspire R7 Speakers Replacement: adım 7, 2 resimden 2.
    • Carefully lift the left-side speaker assembly away from the motherboard.
Sonuç
Andrew Rodiek
601 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G4
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 719
