Ana içeriğe geç
Acer Aspire R7-371T-72CF Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire R7-371T-72CF Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Acer Aspire R7-371T-72CF Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Hard Drive Replacement: adım 3, 3 resimden 1. Acer Aspire R7-371T-72CF Hard Drive Replacement: adım 3, 3 resimden 2. Acer Aspire R7-371T-72CF Hard Drive Replacement: adım 3, 3 resimden 3.
    • Locate the hard drive, as shown to the left. This can be identified by its location underneath the cooling fan and above the ribbon cable (the long horizontal white strip).
  4. Acer Aspire R7-371T-72CF Hard Drive Replacement: adım 4, 2 resimden 1. Acer Aspire R7-371T-72CF Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the Phillips #00 4mm securing screw using your screwdriver.
  5. Acer Aspire R7-371T-72CF Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive by pulling towards the side that was secured by the screw.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dylan Meintser
476 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G5
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,894
