Ana içeriğe geç
Acer Aspire R7-371T-72CF Power Port Replacement
Neye ihtiyacın var
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: adım 1, 2 resimden 1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: adım 1, 2 resimden 2.
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: adım 2, 1 resimden 1.
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: adım 3, 3 resimden 1. Acer Aspire R7-371T-72CF Power Port Replacement: adım 3, 3 resimden 2. Acer Aspire R7-371T-72CF Power Port Replacement: adım 3, 3 resimden 3.
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: adım 4, 3 resimden 1. Acer Aspire R7-371T-72CF Power Port Replacement: adım 4, 3 resimden 2. Acer Aspire R7-371T-72CF Power Port Replacement: adım 4, 3 resimden 3.
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: adım 5, 1 resimden 1.
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethan Frey
117 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G5
5 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
What’s the part number for the power jack cable, and who sells it?
AcerFan - Yanıt
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
Jorge Prado - Yanıt
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - Yanıt
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 1,693
