Giriş
If there is an issue with the charging port on your Acer Aspire, there might be an issue with the power connector. If your laptop is not charging or is charging irregularly, replacing the power connector might help alleviate these issues.
Neye ihtiyacın var
Turn off your laptop and disconnect the power adapter.
Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
Bir başkası bu kılavuzu tamamladı.
