Ana içeriğe geç
Acer Aspire R7-371T-72CF USB Chip Replacement
Neye ihtiyacın var
  1. Acer Aspire R7-371T-72CF USB Chip Replacement, USB Chip: adım 1, 2 resimden 1. Acer Aspire R7-371T-72CF USB Chip Replacement, USB Chip: adım 1, 2 resimden 2.
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 2, 1 resimden 1.
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 3, 3 resimden 1. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 3, 3 resimden 2. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 3, 3 resimden 3.
    • Locate the USB chip, as shown to the left.
    • This can be identified by its location to the left of the cooling fan and above the battery to the left.
  4. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 4, 3 resimden 1. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 4, 3 resimden 2. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 4, 3 resimden 3.
    • Unscrew the two Phillips #00 4mm screws located on the USB chip.
  5. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 5, 3 resimden 1. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 5, 3 resimden 2. Acer Aspire R7-371T-72CF USB Chip Replacement: adım 5, 3 resimden 3.
    • Push the white panel upwards to unlock the cable and then remove the cable.
    • Repeat for the second cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dylan Meintser
476 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G5
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 492
