Ana içeriğe geç
Acer Aspire R7-371T-72CF Wifi Chip Replacement
Neye ihtiyacın var
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: adım 1, 2 resimden 1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: adım 1, 2 resimden 2.
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 2, 1 resimden 1.
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 3, 3 resimden 1. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 3, 3 resimden 2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 3, 3 resimden 3.
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 4, 3 resimden 1. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 4, 3 resimden 2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 4, 3 resimden 3.
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 5, 2 resimden 1. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 5, 2 resimden 2.
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: adım 6, 1 resimden 1.
    • Remove the chip by pulling towards the edge of the computer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dylan Meintser
476 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G5
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 543
