Ana içeriğe geç
Acer Aspire R7-572-6423 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire R7-572-6423 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Battery Replacement: adım 2, 2 resimden 1. Acer Aspire R7-572-6423 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the top and middle rubber feet under the laptop to reveal hidden screws.
  3. Acer Aspire R7-572-6423 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the five 6 mm T9 screws.
    • Remove the eight 10 mm T9 screws.
  4. Acer Aspire R7-572-6423 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the back cover.
  5. Acer Aspire R7-572-6423 Battery Replacement: adım 5, 1 resimden 1.
    • Unplug the ribbon cable connecting the battery to the motherboard.
    • Be careful around the motherboard, as it is easily damaged.
  6. Acer Aspire R7-572-6423 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the three 4 mm Phillips #1 screws securing the battery.
  7. Acer Aspire R7-572-6423 Battery Replacement: adım 7, 2 resimden 1. Acer Aspire R7-572-6423 Battery Replacement: adım 7, 2 resimden 2.
    • Pull open the clips on either side of the battery to free it from the case.
    • Remove the battery from the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 24
Her zaman: 1,518
