Giriş
This guide will walk you through accessing the battery. The battery may need be accessed for replacement or repair. Be careful not to puncture or damage the battery, and dispose of it immediately if it begins to heat up while disconnected.
  1. Remove the 12 5mm Phillips #00 screws. Use a plastic opening tool to gently pry open the back panel. Gently lift up the back panel, exposing the internals of the laptop.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  5. Gently lift the battery from the frame.
    • Gently lift the battery from the frame.
Sonuç
Nikolas I Steckley
521 İtibar
5 adet Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 Gün: 19
Son 30 Gün: 65
Her zaman: 253
