Ana içeriğe geç
Acer Aspire S3 MS2346 Display Assembly Replacement
Neye ihtiyacın var
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: adım 1, 3 resimden 1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: adım 1, 3 resimden 2. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: adım 2, 3 resimden 1. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: adım 2, 3 resimden 2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: adım 2, 3 resimden 3.
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: adım 3, 2 resimden 1. Acer Aspire S3 MS2346 Display Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: adım 4, 1 resimden 1.
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: adım 5, 2 resimden 1. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: adım 5, 2 resimden 2.
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: adım 6, 1 resimden 1.
    • Unlatch the screen from the frame
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nikolas I Steckley
666 İtibar
5 adet Kılavuz yazıldı
Ekip
3 Yorum
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - Yanıt
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 3,177
