Ana içeriğe geç
Acer Aspire S3 MS2346 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: adım 1, 3 resimden 1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: adım 1, 3 resimden 2. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: adım 2, 3 resimden 1. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: adım 2, 3 resimden 2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: adım 2, 3 resimden 3.
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: adım 3, 2 resimden 1. Acer Aspire S3 MS2346 Keyboard Replacement: adım 3, 2 resimden 2.
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: adım 4, 1 resimden 1.
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: adım 5, 2 resimden 1. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: adım 5, 2 resimden 2.
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: adım 6, 1 resimden 1.
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: adım 7, 1 resimden 1.
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: adım 8, 3 resimden 1. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: adım 8, 3 resimden 2. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: adım 8, 3 resimden 3.
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: adım 9, 1 resimden 1.
    • Gently lift the board exposing the keyboard assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nikolas I Steckley
666 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,514
