Ana içeriğe geç
Acer Aspire S3 MS2346 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire S3 MS2346 Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Acer Aspire S3 MS2346 Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Acer Aspire S3 MS2346 Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Motherboard Replacement, Motherboard: adım 2, 3 resimden 1. Acer Aspire S3 MS2346 Motherboard Replacement, Motherboard: adım 2, 3 resimden 2. Acer Aspire S3 MS2346 Motherboard Replacement, Motherboard: adım 2, 3 resimden 3.
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Motherboard Replacement: adım 3, 2 resimden 1. Acer Aspire S3 MS2346 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Motherboard Replacement: adım 4, 1 resimden 1.
    • Gently remove the motherboard.
Sonuç
Nikolas I Steckley
666 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 3,170
