Ana içeriğe geç
Acer Aspire S3-391-6046 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: adım 2, 2 resimden 1. Acer Aspire S3-391-6046 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: adım 3, 1 resimden 1.
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: adım 5, 2 resimden 1. Acer Aspire S3-391-6046 Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: adım 6, 2 resimden 1. Acer Aspire S3-391-6046 Battery Replacement: adım 6, 2 resimden 2.
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: adım 7, 2 resimden 1. Acer Aspire S3-391-6046 Battery Replacement: adım 7, 2 resimden 2.
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 703
