Ana içeriğe geç
Acer Aspire S3-391-6046 Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire S3-391-6046 Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Fan Replacement: adım 2, 2 resimden 1. Acer Aspire S3-391-6046 Fan Replacement: adım 2, 2 resimden 2.
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Fan Replacement: adım 3, 1 resimden 1.
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Unscrew the three screws with a Phillips #0 screwdriver.
  5. Acer Aspire S3-391-6046 Fan Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use either your hands or the tweezers to gently peel back the tape.
  6. Acer Aspire S3-391-6046 Fan Replacement: adım 6, 2 resimden 1. Acer Aspire S3-391-6046 Fan Replacement: adım 6, 2 resimden 2.
    • Do not pull anything by the wires.
    • Use the tweezers to gently pull the small black plug out.
    • After the plug is out, you should be able to pull the fan assembly out.
Sonuç
Connor Talbot
99 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 575
