Ana içeriğe geç
Acer Aspire S3-391-6046 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire S3-391-6046 Keyboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Keyboard Replacement: adım 2, 2 resimden 1. Acer Aspire S3-391-6046 Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Keyboard Replacement: adım 3, 1 resimden 1.
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • Remove the four Phillips #0 screws that are connected to the left and right speakers.
    • Carefully disconnect the wires that connect the speaker to the rest of the computer.
  5. Acer Aspire S3-391-6046 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove two Phillips #0 screws that are beside the ends of the gray wire.
  6. Acer Aspire S3-391-6046 Keyboard Replacement: adım 6, 3 resimden 1. Acer Aspire S3-391-6046 Keyboard Replacement: adım 6, 3 resimden 2. Acer Aspire S3-391-6046 Keyboard Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the gray wire slowly with tweezers.
    • Carefully peel wire off.
  7. Acer Aspire S3-391-6046 Keyboard Replacement: adım 7, 2 resimden 1. Acer Aspire S3-391-6046 Keyboard Replacement: adım 7, 2 resimden 2.
    • Slowly remove the two wires that are to the left of the battery with tweezers in an upward pulling motion.
  8. Acer Aspire S3-391-6046 Keyboard Replacement: adım 8, 2 resimden 1. Acer Aspire S3-391-6046 Keyboard Replacement: adım 8, 2 resimden 2.
    • Completely remove the battery out of its position.
  9. Acer Aspire S3-391-6046 Keyboard Replacement: adım 9, 2 resimden 1. Acer Aspire S3-391-6046 Keyboard Replacement: adım 9, 2 resimden 2.
    • Remove the five Phillips #0 screws that are on the border of the laptop.
    • Disconnect the white wire that is below the fan.
  10. Acer Aspire S3-391-6046 Keyboard Replacement: adım 10, 2 resimden 1. Acer Aspire S3-391-6046 Keyboard Replacement: adım 10, 2 resimden 2.
    • Flip all of the circuits upwards.
    • Remove all Phillips #0 screws.
    • Remove the keyboard.
Sonuç
Brian Jimenez
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 826
