Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your laptop doesn't play sound, use this guide to remove and replace your speakers. For this guide, you will need a PH00 screwdriver head and tweezers.
Parçalar
Hiçbir parça belirtilmedi.
  1. Place laptop upside down.
    • Place laptop upside down.
  2. Remove the twelve 5mm screws with a Phillips #1 screwdriver. Remove the twelve 5mm screws with a Phillips #1 screwdriver.
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Lift cover upwards away from you.
    • Lift cover upwards away from you.
  4. Remove the two Phillips #0 screws from the left speaker. Remove the speaker. Remove the speaker.
    • Remove the two Phillips #0 screws from the left speaker.
    • Remove the speaker.
  5. Remove the two Phillips #0 screws from the right speaker.
    • Remove the two Phillips #0 screws from the right speaker.
    • Do not lift the speaker.
  6. Remove the black tape above the right speaker. Remove the right speaker. Remove the right speaker.
    • Remove the black tape above the right speaker.
    • Remove the right speaker.
  7. Remove the white connector above the black tape. Remove the white connector above the black tape. Remove the white connector above the black tape.
    • Remove the white connector above the black tape.
  8. The speakers are fully disconnected.
    • The speakers are fully disconnected.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Skylar Werner
270 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 110
