Ana içeriğe geç
Acer Aspire S3-951-6432 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire S3-951-6432 Battery Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire S3-951-6432 Battery Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire S3-951-6432 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Keeping it closed, turn the laptop upside down.
    • With the Phillips #0 screwdriver, remove the twelve 5 mm screws that hold the laptop together.
    • Insert the plastic opening tool between the plastic casings to pull the bottom lid of the laptop up.
    • You do not need to pull the lid all the way off.
  2. Acer Aspire S3-951-6432 Battery Replacement: adım 2, 3 resimden 1. Acer Aspire S3-951-6432 Battery Replacement: adım 2, 3 resimden 2. Acer Aspire S3-951-6432 Battery Replacement: adım 2, 3 resimden 3.
    • Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip.
    • Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket.
    • The battery is now disconnected. If you want to remove the battery, follow the remaining steps in this guide. However, if you only wish to disconnect the battery to do other internal work, skip the remaining steps in this guide and continue on to other guides.
  3. Acer Aspire S3-951-6432 Battery Replacement: adım 3, 1 resimden 1.
    • With the Phillips #0 screwdriver, remove the two 5 mm screws that are located above the long black piece of the battery.
  4. Acer Aspire S3-951-6432 Battery Replacement: adım 4, 3 resimden 1. Acer Aspire S3-951-6432 Battery Replacement: adım 4, 3 resimden 2. Acer Aspire S3-951-6432 Battery Replacement: adım 4, 3 resimden 3.
    • Locate the two speakers for this laptop that are connected above the battery by a thin red cord.
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place.
    • Pull the left speaker up along with the red cord and leave it off to the right side.
    • If you plan to disassemble the laptop down to the motherboard, you will also need to remove the two 3 mm screws holding the right-side speaker in place with a Phillips #0 screwdriver.
  5. Acer Aspire S3-951-6432 Battery Replacement: adım 5, 1 resimden 1.
    • Without bending it, lift the entire battery (both the long black piece and the rectangular blue piece) straight up. Place it off to one side.
Sonuç
Cynthia Bennett
584 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Rose Fall 2018 UW Tacoma, Team S1-G1, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G1
4 Üyeler
1Rehber Yorum
Hello there! How about CMOS battery of this model Acer Apire S3 951? I can’t find it where to change or replace.. I hope you can provide me procedure. God bless ang more power to you iFixit.
Romel Conquilla - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,299
