Ana içeriğe geç
Acer Aspire S7-392-6484 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire S7-392-6484 Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire S7-392-6484 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Battery Replacement: adım 2, 1 resimden 1.
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Battery Replacement: adım 3, 1 resimden 1.
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Wise
754 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Eyestone Spring 2018 USF Tampa, Team S2-G6, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 5,430
