Ana içeriğe geç
Acer Aspire S7-392-6484 Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: adım 1, 2 resimden 1. Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: adım 1, 2 resimden 2.
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Acer Aspire S7-392-6484 Solid State Drive Replacement: adım 2, 2 resimden 1. Acer Aspire S7-392-6484 Solid State Drive Replacement: adım 2, 2 resimden 2.
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Acer Aspire S7-392-6484 Solid State Drive Replacement, Solid State Drive: adım 3, 1 resimden 1.
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  4. Acer Aspire S7-392-6484 Solid State Drive Replacement: adım 4, 1 resimden 1.
    • Remove the hard drive by pulling it away horizontally from its connection.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nicholas Wise
754 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Eyestone Spring 2018 USF Tampa, Team S2-G6, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 2,593
