Ana içeriğe geç
Acer Aspire S7-392-6484 LCD Replacement
Neye ihtiyacın var
  1. Acer Aspire S7-392-6484 LCD Replacement, LCD: adım 1, 2 resimden 1. Acer Aspire S7-392-6484 LCD Replacement, LCD: adım 1, 2 resimden 2.
    • Use a heat gun to heat the edges of the screen, loosening the adhesive underneath.
    • Run a jimmy or similarly thin object around the edge of the screen.
    • Using a suction cup, lift up on the screen to separate it from the adhesive.
    • Be aware that the screen will most likely crack significantly during these steps. Be prepared to immediately replace the LCD should you undertake this repair.
  2. Acer Aspire S7-392-6484 LCD Replacement: adım 2, 2 resimden 1. Acer Aspire S7-392-6484 LCD Replacement: adım 2, 2 resimden 2.
    • Turn over the display to show the connectors underneath.
    • Disconnect the marked connectors to remove the display from the casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Wise
754 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Eyestone Spring 2018 USF Tampa, Team S2-G6, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G6
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 38
Her zaman: 1,833
