Ana içeriğe geç
Acer Aspire S7-392-6484 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire S7-392-6484 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire S7-392-6484 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Motherboard Replacement: adım 2, 1 resimden 1.
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Motherboard Replacement: adım 3, 1 resimden 1.
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the battery.
  5. Acer Aspire S7-392-6484 Motherboard Replacement, Fan: adım 5, 2 resimden 1. Acer Aspire S7-392-6484 Motherboard Replacement, Fan: adım 5, 2 resimden 2.
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  6. Acer Aspire S7-392-6484 Motherboard Replacement: adım 6, 2 resimden 1. Acer Aspire S7-392-6484 Motherboard Replacement: adım 6, 2 resimden 2.
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  7. Acer Aspire S7-392-6484 Motherboard Replacement, Solid State Drive: adım 7, 1 resimden 1.
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  8. Acer Aspire S7-392-6484 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the hard drive by pulling it away horizontally from its connection.
  9. Acer Aspire S7-392-6484 Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove all marked 2mm screws using a Phillips #1 screwdriver.
    • Disconnect the orange marked connectors.
    • The connectors will take a decent amount of force to disconnect. This will not damage your device, so use the necessary force to disconnect them.
  10. Acer Aspire S7-392-6484 Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift up on the motherboard to pull it out of the casing.
Sonuç
Nicholas Wise
754 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Eyestone Spring 2018 USF Tampa, Team S2-G6, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G6
3 Üyeler
Bir Yorum
Hi Nicholas.
I was wondering if you really changed yours or just opened it. I need to change now mine and I’m not sure that the new one will be able to read my SSD which is Raid 0 without losing my data… Acer is famous for its stupidity of having a 1 drive Raid 0,
Thanks
Mr Man - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,995
