Giriş
If your device can't power on or has trouble retaining charge, you may need a new battery. Use this guide to replace the battery on your device.
Neye ihtiyacın var
Wedge your plastic opening tool into the crevice on the volume rocker and pull down like a lever to create space.
Slide the plastic opening tool along the crevice to separate the back plate.
9 farklı kişi bu kılavuzu tamamladı.
3 Yorum
How can i get a cmos battery off that pc
How does the Switch 10 back removal process differ from the Switch Alpha 12 back removal process. You don’t have much in the stored “fixes” files for the Switch Alpha 12. Can anything here apply to the “12” too? THANKS
