Ana içeriğe geç
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 2, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 2, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 2, 3 resimden 3.
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 3, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 3, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 3, 3 resimden 3.
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 4, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 4, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 4, 3 resimden 3.
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 5, 2 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Max Francois
684 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 7,357
