Ana içeriğe geç
Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: adım 1, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: adım 1, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: adım 1, 3 resimden 3.
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 2, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 2, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 2, 3 resimden 3.
    • There is one zero insertion force connector that needs to be removed.
    • Use your plastic opening tool to flip up the black clip that secures the ribbon cable to the motherboard.
    • Once the clip is flipped up, the ribbon cable will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 3, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 3, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 3, 3 resimden 3.
    • To remove the four bundled cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  4. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 4, 2 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 4, 2 resimden 2.
    • Use a pair of tweezers to gently pull up the speaker closest to the motherboard.
  5. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 5, 2 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 5, 2 resimden 2.
    • Remove any tape that may be holding down the speakers or wires in place.
  6. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 6, 2 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 6, 2 resimden 2.
    • Use tweezers to gently pull up the second speaker.
  7. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: adım 7, 1 resimden 1.
    • Remove and replace the speakers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Richard Colon
480 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,346
