Ana içeriğe geç
Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: adım 1, 1 resimden 1.
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: adım 2, 2 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: adım 2, 2 resimden 2.
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: adım 3, 3 resimden 1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: adım 3, 3 resimden 2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: adım 3, 3 resimden 3.
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: adım 4, 1 resimden 1.
    • Remove the touchpad.
Sonuç
Max Francois
684 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G4
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,563
