Ana içeriğe geç
Giriş
The track pad on this device has a habit of breaking. It can sometimes sink into the keyboard or stop responding altogether. This guide will help you replace a faulty track pad.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Push the plastic opening tool into the crevice between the front and back panel. Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable. Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable. The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Remove the touchpad.
    • Remove the touchpad.
Sonuç
Max Francois
603 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G4
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
Her zaman: 1,084
