Giriş
The track pad on this device has a habit of breaking. It can sometimes sink into the keyboard or stop responding altogether. This guide will help you replace a faulty track pad.
Neye ihtiyacın var
Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
This screw does not need to be removed because it doesn't hold the backplate in.
Bir Yorum
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
