Ana içeriğe geç
Acer Aspire Switch 10 SW5-012-18MY Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 2, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 2, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 2, 3 resimden 3.
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 3, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 3, 2 resimden 2.
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 4, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 4, 2 resimden 2.
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 5, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 5, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 5, 3 resimden 3.
    • Use the opening tool to lift the ZIF connector holding the ribbon cable in place on the circuit board.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 6, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 6, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 6, 3 resimden 3.
    • Remove the piece of thin, black tape that is attached to the circuit board on the other side of the battery.
    • Use the opening tool to lift the black ZIF connector holding the ribbon cable in place.
  7. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 7, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 7, 2 resimden 2.
    • Partially remove the piece of black tape that is holding the bundled cable connector to the battery in place.
    • Pull on the battery's bundled cable connector to unplug it from the circuit board.
  8. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove the 3 mm screw that is holding the battery in place.
  9. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 9, 1 resimden 1.
    • Gently remove the ribbon cable from the battery.
  10. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 10, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: adım 10, 2 resimden 2.
    • Carefully remove the battery from the device by lifting it up.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Grecia Corrada
1.134 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 83
Her zaman: 5,002
