Ana içeriğe geç
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: adım 1, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: adım 1, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: adım 1, 3 resimden 3.
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 2, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 2, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 2, 3 resimden 3.
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 3, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 3, 2 resimden 2.
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 4, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 4, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 4, 3 resimden 3.
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 5, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 5, 2 resimden 2.
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 6, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 6, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 6, 3 resimden 3.
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 7, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 7, 2 resimden 2.
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 8, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 8, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 8, 3 resimden 3.
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 9, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 9, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: adım 9, 3 resimden 3.
    • Pull the docking connector off of the screen section.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Grecia Corrada
1.134 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G3
3 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Where do you get the docking ports or whatever it is called? With the magnets
Michael - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 3,099
