Ana içeriğe geç
Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: adım 1, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: adım 1, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: adım 1, 3 resimden 3.
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover with the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 2, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 2, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 2, 3 resimden 3.
    • Lift up on the ZIF connector that secures the ribbon cable using the opening tool.
    • Pull the ribbon cable free.
  3. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 3, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 3, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 3, 3 resimden 3.
    • Remove the 4, 2.5 mm screws from the trackpad cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 4, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 4, 2 resimden 2.
    • Remove the metal piece that secures the trackpad cover in place using the opening tool.
  5. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 5, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 5, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: adım 5, 3 resimden 3.
    • Remove the trackpad using the opening tool and your hands.
Sonuç
Grecia Corrada
1.134 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G3
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 921
