Giriş
If the motherboard of your Acer Aspire TimelineU M5-481TG has been compromised or is damaged, use this guide to replace it.
Before performing any repairs, make sure the laptop is fully powered off and disconnected from its charger. Removing the motherboard involves first removing the keyboard and the battery, and the rest can be done with using just your hands.
Replacing the motherboard could result in the deletion of all Desktop files. Make sure you try other forms of troubleshooting and replacement before resorting to motherboard replacement.
Neye ihtiyacın var
With the laptop closed and powered off, place the laptop screen side down.
Turn the laptop so that the hinges are closest to you.
Remove sixteen 6 mm screws from the bottom of the laptop with the Phillips #00 screwdriver.
Hold the keyboard open with one hand to extend the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case.
Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
Gently disconnect the silver cable that stretches over the battery by using your fingernail to flip up the small retaining flaps on both sides of the zero insertion force connector.
Gently lift up the black-covered cables that remain connected to the motherboard at the bottom left of the laptop base.
Move the cables toward the bottom edge of the laptop closest to you without disconnecting them.
Carefully lift up the motherboard and slide the battery to the left to pull it out.
Use your fingernail to flip up the small retaining flap of zero insertion force connector and then gently out pull the silver ribbon cable.
