Ana içeriğe geç
Acer Aspire TimelineU M5-581T-6807 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineU M5-581T-6807 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the screws, indicated by the circles in the picture, from the back panel using the PH1 attachment.
  2. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: adım 2, 1 resimden 1.
    • Note: The back panel cannot be removed. Flip the laptop and remove the keyboard to access the components.
  3. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: adım 3, 1 resimden 1.
    • With the keyboard removed, Locate the battery as seen in the picture. Remove the wire connection above the battery by hand. Grab all the wires and shim the connector out of position.
  4. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: adım 4, 1 resimden 1.
    • Locate and remove the Phillips #1 screw holding the battery in place using the PH1 attachment.
  5. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: adım 5, 1 resimden 1.
    • Pry the battery upwards, using the iFixIt opening tool, to remove it out of the holder.
  6. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: adım 6, 1 resimden 1.
    • Now the battery is exposed and ready for replacement.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Edwin VanBaale
256 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Hovde Spring 2019 IUPUI, Team S1-G1, Hovde Spring 2019 üyesi
IUPUI-HOVDE-S19S1G1
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 2,254
