Ana içeriğe geç
Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Battery: adım 1, 1 resimden 1.
    • Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
  2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 2, 3 resimden 1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 2, 3 resimden 2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 2, 3 resimden 3.
    • Hold the battery release button, and pull the battery out of the laptop.
  3. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: adım 3, 3 resimden 1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: adım 3, 3 resimden 2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: adım 3, 3 resimden 3.
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  4. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 4, 3 resimden 1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 4, 3 resimden 2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 4, 3 resimden 3.
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  5. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 5, 2 resimden 1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  6. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 6, 2 resimden 1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 6, 2 resimden 2.
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  7. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 7, 3 resimden 1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 7, 3 resimden 2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: adım 7, 3 resimden 3.
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  8. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: adım 8, 3 resimden 1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: adım 8, 3 resimden 2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: adım 8, 3 resimden 3.
    • Detach the covered wires that connect the motherboard to the Bluetooth.
    • Remove the Bluetooth module by hand to then replace it.
Sonuç
Brenna Waterbury
523 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 890
