Ana içeriğe geç
Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Remove the device's battery before beginning.
    • Turn laptop so under side is facing up.
    • Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
  2. Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Pry open hard drive cover using the Spudger tool.
  3. Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement: adım 3, 3 resimden 1. Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement: adım 3, 3 resimden 2. Acer Aspire TimelineX 1830T-68U118 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Remove screw attached to the hard drive using the PH0 mm Phillips Head.
    • The hard drive can now be removed from the device.
Sonuç
Brenna Waterbury
523 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 900
