Ana içeriğe geç
Acer Aspire TimelineX 4820T-6645 Wifi Module Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: adım 2, 1 resimden 1.
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: adım 3, 2 resimden 1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: adım 3, 2 resimden 2.
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: adım 4, 2 resimden 1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: adım 4, 2 resimden 2.
    • Flip the laptop over and remove screws (PH#1, 8mm length) holding the back cover in place
    • Remove back cover from your laptop
  5. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: adım 5, 2 resimden 1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: adım 5, 2 resimden 2.
    • Disconnect the two antenna cables from the WLAN board as shown below
    • Black wire is terminal 1(left), white wire is terminal 2(right)
  6. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: adım 6, 1 resimden 1.
    • Remove the screw(PH#1, 3mm length) holding the WLAN board to the laptop
  7. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: adım 7, 1 resimden 1.
    • Detach and remove the WLAN board from the WLAN socket
Sonuç
Dylan Bryda
109 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 226
