Ana içeriğe geç
Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: adım 2, 1 resimden 1.
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: adım 3, 2 resimden 1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: adım 3, 2 resimden 2.
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
  5. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: adım 5, 1 resimden 1.
    • After removing the back panel, use a Phillips #1 screwdriver to unscrew the two 8 mm screws that hold the retaining piece to the frame.
  6. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: adım 6, 2 resimden 1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Pull the plastic tab toward the frame to disconnect the hard drive SATA.
  7. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the hard drive from the laptop, and use a Phillips #1 screwdriver to unscrew the two 3 mm screws that secure the retaining piece to the hard drive.
Sonuç
Ian Smiley
109 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 579
