Giriş
If you need to replace your hard drive due to technical problems or any other reason, use this guide to gain access to it. In order to conduct this repair, you will need a Phillips head screw driver with a PH 1 head. This is a relatively simple process and should pose a significant challenge or risk harm to your device as long as it is powered off.
Neye ihtiyacın var
Power down the laptop.
Turn the laptop over so the bottom is facing up and the battery is facing towards you.
Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
