Giriş
The CPU is not a common failure component, but may fail due to a failed cooling fan that caused it to overheat.
This guide provides simple steps to replace the CPU on the Acer Aspire TimelineX 4830T-6682 using minimal tools that can be acquired locally, or through iFixit. Please make sure and follow the prerequisite procedures.
Neye ihtiyacın var
Remove the single screw with a Phillips #0 screwdriver.
Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
After the panel has been removed, locate the RAM. It should be on the lower right.
There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
The battery will be on the side closest to the screen.
Gently lift it out. It will still be attached by white, red, and black wires.
Turn the CPU screw counterclockwise 180 degrees with a Flathead 2.5mm screwdriver
Bir başkası bu kılavuzu tamamladı.
3 Yorum
Followed instructions computer now dosnt turn on
Hello Ian,
If you would like me to help troubleshoot your computer, please provide more details by answering the following questions?
Was the computer booting before following the CPU replacement instructions?
What troubleshooting was completed to determine the CPU had to be replaced?
Was the CPU replacement part verified as working before installation?
Is the computer powering up to any screen, showing partial boot?
